Problem Installing a Product
Brotherlobo
I just purchased Destroyer HMS August and now I am getting an error message when the 'DAZ 3D Install Manager' tries to install it.
Here is the message: Install Manager cannot find a required path. The installer for "Destroyer HMS August" requires that the installed path for "Carrara 8.5;8" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
There is a reason that path is not defined...I don't have Carrara. But this item is listed for DAZ Studio & Poser. Need some help here or am I just out of luck on my money spent?
This is a Carrara only model. I suggest you return it and ask for a refund, and we will report the wrong compatability issue to DAZ 3D.
