G2F install
rumpotrumpot Posts: 96
All my content is in /users/{username}/Documents/DAZ 3D/Studio/My Library
and the G2F installed to /Users/Shared/My DAZ 3D library
When I changed the install path of the DIM I got the warning so I left it top shared, buts it's kinda a pain to have to search in yet another location
Is it safe to ignore the warning and install to my regular location?
Regards
Eric
  • Richard HaseltineRichard Haseltine Posts: 112,272
    Yes. The warning mainly relates to installing something with DIM in a folder where it had previously been installed with the old BitRock installers - since G2F is new that won't be an issue.
  • rumpotrumpot Posts: 96
    Thanks. I uninstalled, changed the directory, and reinstalled. Now loading G6pro.
    I have a coupla issues/questions:
    I can only access the G2F from the library and not the smart content, do I need to rescan something?
    Is the DIM smart enough to mark or overwrite my existing installs if I d/l & install through it? Fer instance, what will happen it I use the DIM to install V5, which I had already done with bitRock, since these point to the same location would the installer just overwrite the existing files or will I have any side effects?
    Regards
    Eric
  • fixmypcmikefixmypcmike Posts: 19,744
    Regards
    Eric
    DIM will just overwrite the files -- the only potential problem is if the product has been updated and some files were removed or moved to different locations -- since the original installation was with a Bitrock installer, DIM doesn't know that those files need to be removed.
