platinum
chiendorchiendor Posts: 0
hello i would like to join your platinum for 3 months and aftet pro month
the problem is ican not get it into my shopping cart
i did log in
please help
regards Geertje
    edited August 2013
    Are you trying to purchase from this page
    http://www.daz3d.com/platinum-club-quarterly/
    Try adding another item to you cart, and item and then view your cart and see what it shows.
    Post edited by Chohole on
  • srieschsriesch Posts: 4,243
    After you have added that random 2nd item to the cart, you can then immediately delete it back out of the cart, leaving you with only the item you want in the cart.
    It just often gets stuck with the first item and says there's nothing in your cart so you can't get to it, but if you try to add that item again it says it IS in your cart. The add/delete thing has always worked for me to jog it's memory.
  • Richard HaseltineRichard Haseltine Posts: 111,831
    But you are a Platinum Club member, according to your profile. If that isn't since your previous post then it would probably explain why you can't add the new membership to your cart.
