What are you wanting to chieve? There is a Backface Lighting option in Edit>Preferences>Interface tab, and it is possible to use a shader from Shader Mixer to have different behaviour depending on facing (certainly in 3Delight, i've doen it, and I believe in Iray too).
You may want to have the polygons two / double sided - has something to do with the face normals pointing out in both directions inside and outside I think.
Which Daz3D program? Studio or Hex?
I think it can be done using geoshells and a shader on the inner one, Oso 3D possibly knows
I don't use DAZ studio's render engines
Shader-mixer: Double sided materials? YES! (SOLVED)
I have not found a way to do this in Iray/MDL. I would love to find out a method!
I have Backface Lighting on in the Edit>Preferences>Interface tab, but the backfaces are still black. Is there any other setting that effects them?
