Just want to convert into obj
in New Users
hello,
i am absolutely new to DAZ and just use it, cause I needed it in order to open some dsf files I purchased and downloaded from Renderosity. But I tried for hours now and can’t figure out how to get that to work. When I try to open the dsf files directly, then an error message comes. The log file is of no help for me. When I try to install the files manually to my library then daz cant find them, even after hours. So my question is, as I already give up here, would someone be so kind, and could convert me the files to obj ? I would send you a download link via pm then
thanks in advance
Generally a .dsf file is not a user-facing file, it's one that goes in the Data folder - in a specific sub-folder - and is loaded by a .duf file or adds to another item and is loaded as part of that item once correctly installed (a morph or UV set, for example). Older content, DS 4 but before 4.5, did use .dsf for both asset and user files so it isn't absolutely certain that that applies here, but it is likely. Without more information it's impossible to give more conrete advice.
you can actually convert a dsf to obj using a D3D product
https://www.daz3d.com/dsf-toolbox
That does assume it's a figure or prop, though.
