dForce and transparency
When simulating a dForce item against a static item that has a transparency map, does dForce take into account the transparency?  Or does it simulate against the static item's mesh without regard for transparency?
  • It still "sees" the mesh, just as if you set it to wireframe view.
    dForce has Matrix Vision lol
    However, if the object is Hidden, dForce will ignore it.
  • SimonJMSimonJM Posts: 6,100
    You can set a (whole) material zone/surface to be unaffacted by dForce, which may not be the effect you are after, but may help.
  • rames44rames44 Posts: 336
    Thanks.  I wasn't actually trying to use transparency in a simulation - I was trying to explain some issues I was having with one simulation, and wanted to make sure that that wasn't what was going on.
