howto random replicate over terrain?
forgot howto,have done it earlier
also hope it is possible to turn terrain invisible,but not the objects I replicated
M
  • DiomedeDiomede Posts: 15,454
    edited August 2018
    There are two types of replicators on the same drop down menu.  Just drag the surface replicator on to your terrain object. The replicator menu will appear.
    The following thread may be helpful.  http://www.daz3d.com/forums/discussion/38177/
    Post edited by Diomede on
    To turn any object invisible, just unceck the box for visibility in the "General" tab of the object's property tray (upper right of interface)
  • mach25mach25 Posts: 256
    thanks for your advice DIomede
    M
  • HeadwaxHeadwax Posts: 10,562
    you could also use noise in your replication shader
    And you can replicate a relocated object.  Nested replicators can get you more density.
