Error during rendering - never encountered this before (log included)
Ulysses0302
I was rendering a simple Iray scene (1 G8M, hair, clothes) in the "Window Seat" set with the standard dome as light source. Then after half an hour of rendering, Daz suddenly stopped. I was unable to save the render though it looked okay (the temp folder was empty) and the viewport remained black, later, Studio crashed while closing. The log file said what follows below, alas, I am unable to read anything out of this. Was this a random bug? I never encountered any issues with Studio before. Even with much bigger scenes.
2018-08-12 01:24:30.927 Iray VERBOSE - module:category(IRAY:RENDER): 1.0 IRAY rend progr: 69.13% of image converged
2018-08-12 01:24:34.734 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00197 iterations after 1498.867s.
2018-08-12 01:26:25.429 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00211 iterations after 1609.556s.
2018-08-12 01:27:51.071 Loaded image DTHDR-RuinsB-500.hdr
2018-08-12 01:27:51.817 WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(API:DATABASE): 1.0 API db warn : Transaction is released without being committed or aborted. Automatically aborting.
2018-08-12 01:27:51.817 WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(DB:DATABASE): 1.0 DB db warn : Aborting transaction while transaction is blocked!
2018-08-12 01:28:00.714 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00223 iterations after 1704.836s.
2018-08-12 01:28:00.802 Iray VERBOSE - module:category(IRAY:RENDER): 1.0 IRAY rend progr: Transaction closed, stopping renderer.
2018-08-12 01:28:00.830 WARNING: QWidget::repaint: Recursive repaint detected
2018-08-12 01:35:47.668 Loaded image DTHDR-RuinsB-500.hdr
2018-08-12 01:35:47.701 Total Rendering Time: 36 minutes 15.56 seconds
I've got no idea what may have caused this, but you're not the 1st one having this problem....
https://www.daz3d.com/forums/discussion/53891/iray-crashing-on-render (here it is mentined thay the subd render level >1 may have been the cause)
https://www.daz3d.com/forums/discussion/250331/iray-fails-after-rendering-1-frame
Thanks, I'll check into that. I had found other threads with that issue but none of those got resolved so I thought it might be something unique which only causes the same error message in each case. I used some items I had never used before in that scene to set up some clutter on the shelves of the "Window Seat" maybe one of those caused the issue since I had used the G8M character several times before.
