Iray Fails After Rendering 1 Frame
I am just getting back to DAZ Studio after being off for about two months. I have updated everything through Install Manager and Daz Studio is at the latest released rev.
I get the error shown below after Rendering a single frame of my Animation. The Frame renders fine but the next one fails immediately. This is with a GeForce GTX 1070 TI with the latest Drivers installed and Daz Studio 4.10.0.123. A small popup appears when it fails simply saying something basic like "An Error Occurred". When I click OK on the popup the Mouse Pointer looks like DAZ Studio is busy, but I can click on things.
If I try to Render again I get "Unable to render. Renderer is already in use." I was having a similar problem with a Scene last week but it seemed to go away once I turned off Iray Rendering in the Viewport (which I usually do anyway).
I tried removing some objects that I had added to the scene and also removed hidden objects & figures from the Scene with no luck.
I read where someone else has a similar error and they though it was due to SubD being greater than 1. I am not sure where this would be set but maybe that could be my issue.
One thing I noticed in trying to debug this is that in Windows 10 Task Manager, there is an instance of Daz Studio Application that appears to be taking up 4-5GB of memory. In the Gpu Engine column it show "gpu 0 copy". Maybe this is just how Windows is showing the GPU usage but I thought it might be a clue.
I have my Advance Render settings set to GPU only with OptiX Prime Acceleration enable. I am attachning a screenshot of my Render settings.
18-05-03 11:58:27.894 Iray VERBOSE - module:category(IRAY:RENDER): 1.0 IRAY rend progr: 94.80% of image converged
2018-05-03 11:58:27.916 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 02161 iterations after 908.421s.
2018-05-03 11:58:37.041 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 02183 iterations after 917.547s.
2018-05-03 11:58:46.212 Iray VERBOSE - module:category(IRAY:RENDER): 1.0 IRAY rend progr: 95.02% of image converged
2018-05-03 11:58:46.243 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 02205 iterations after 926.748s.
2018-05-03 11:58:46.243 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Convergence threshold reached.
2018-05-03 11:58:55.426 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Device statistics:
2018-05-03 11:58:55.427 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : CUDA device 0 (GeForce GTX 1070 Ti): 2227 iterations, 26.186s init, 909.689s render
2018-05-03 11:58:56.001 Saved image: D:\DazContent\My Library\Sorority Sweethearts\Scenes\Vixens\Riley - First Approach\Series\Riley - First Approach - 80.png
2018-05-03 11:58:56.003 Rendering frame 81
2018-05-03 11:59:05.871 WARNING: dzneuraymgr.cpp(307): Iray WARNING - module:category(API:DATABASE): 1.0 API db warn : Transaction is released without being committed or aborted. Automatically aborting.
2018-05-03 11:59:11.518 Total Rendering Time: 16 minutes 15.46 seconds
