Reshape help
I am rather new to Hexagon and am having an issue.
I am trying to reshape a medieval shield from a pointed top to a smooth rounded top but cannot figure out how to reshape in Hex, any help?
Hard to tell without picture. You can try using Taper option from Utilities (icon looks like pyramid). Select your model, click on Taper and small menu will appear, pick the last one, deformer. It will make a cage / grid around your item and when you push/pull points on the cage, it will move parts of your model. For selecting more than 1 point on the cage press and hold shift key on keyboard . Click validate when you are done.
Okay, got that done, now I am having an issue where it is using a mirror texture, how do I get this to stop?
