[Solved] Saving JCM Morphs
231286231286 Posts: 0
edited July 2018 in New Users
Hello i have a Question about JCM Morphs and how to Save them.Question:
  • I created a JCM Morph => and put it in Hidden / Peopel Folder
  • The JCM Morph Shold work with Eye Closed Right
  • So i opened the JCM Morph with "Property Hierarchy" Under "Controlers" i put the "Right Eye Close" Morph into the 1st Stage (Add/Subtract) and the "Model Head Morph" under 2nd Stage (Multiply/Divide)
  • So after that is done i can slide Right Eye Close and Open andthe MORPH goes with it "Perfect"
  • Now Saving => File "Save As" => "Support Asset" => "Morph Assets" => Chosing the JCM i created and SAVE.
When i Close now Daz3d and reopen it and apply the HEAD and try to "Close the Right Eye" the JCM dont activate ... and if i check the "Property Hierarchy" under 1st Stage and 2nd Stage there is nothing even i addet the Head and the Close Eye. Where exactl did i do a mistake?
Best Regards
Post edited by 231286 on
  • Richard HaseltineRichard Haseltine Posts: 111,929
    Make sure, under the link's attributes in the Property Hierarchy, that it is set to save with your morph not with the eyes closed morph.
  • 231286231286 Posts: 0
    Thanks you very much, I found t he error it was on my Side. I bugged / broken Daz that i just uninstalled it and reinstalled it. Now it works like a Swiss Clock.
    Thanks you
