light emitter reflection
Hi,
I've checked off the light emitter but i can still see it in reflective surfaceses, is there any way to disable that?
Thanks
  • SimonJMSimonJM Posts: 6,102
    If it has geometry it will be seen. Set Opcaity down on the emissive surface or hide item in scene?
  • Richard HaseltineRichard Haseltine Posts: 111,745
    Render Emitter off affects only the direct line of sight, if the light is seen through a surface or in a reflection it will still render.
  • abunezekabunezek Posts: 32
    I realised that the hard way. so what is the trick?
    As SimonJM says, set teh Cutout Opacity to a very low but non-zero value. Just be aware that Iray doesn't do pseudo specularity, if the light isn't reflecting there will be no hihglights, so you may find the end rsult is too mat.
    I will try that.
    Thanks
  • Steel RatSteel Rat Posts: 417
    Old thread, I know, but I wasn't finding anything more recent on this topic.
    There's no cutout opacity on a point light set as a rectangle, there are no surface settings at all. So is there a way to prevent the rectangle from showing in reflected surfaces?
  • felisfelis Posts: 6,561
    It is only emissive surfaces that have cut-out oppacity. Lights do not.
    Right, but this thread didn't specify mesh lights. So I was hoping there was a way.
