G8F hip/pelvis distortion
Hi,
            I have a recuring issue with G8F hip/pelvis as per my screen grab. I'm not sure why only G8F is effected as G3F is fine. Anyone got any ideas of whats up?
Post edited by cottrellitunes on
  • LeanaLeana Posts: 13,499
    You can't post a pic with a nude figure in the forums unless you set your viewport to smooth shaded view.
    As for the problem you have, is that a default G8F figure?
    If you look in the "currently used" section, are there parameters with non-zero values? (especially hidden morphs)
  • All zero and is the default figure. Well not all zero as it a default pose and thus some deviation.
    Sorry if you were offended by the nudity is that a forum rule?
    edited June 2018
    Yes. Take the texture off or put clothes on the figure before the mods see it.
    https://www.daz3d.com/terms-of-service
    Post edited by Male-M3dia on
  • Corrected albeit no solution to issue as of yet
  • TooncesToonces Posts: 919
    Sometimes a base figure can get slightly 'corrupted' by an installed morph. I've read threads on it. Unfortunately, I can't recall the solution off hand (I think it involves uninstalling/reinstalling/looking for the stuff that included the bad morph).
    For me, Base G8F poses fine (see attached).
    Also, I don't think black bars are acceptable, according to the forum rules: https://www.daz3d.com/forums/discussion/3279/acceptable-ways-of-handling-nudity#latest
    622 x 602 - 133K
  • nicsttnicstt Posts: 11,715
    edited June 2018
    with the parameters tab selected (as it is in the first image), highlight currently used.
    You may have to show hidden properties; right click on the parameter's tab.
    that should display what is in use including those normally hidden; it may be as something as simple as a morph being included that shouldn't be.
    ... Of course, it could also be something not included that should.
    It looks like something is messed up with your install; it can happen rarely for no apparent reason; more often, users have saved something or deleted something. It happens when we're trying stuff. :)
    As explained above, it can also be an installed morph.
    Has it previously worked? What have you installed recently, if it did previously work?
    You may have to try:
    Uninstall everything (delete the folders if they are still there. REMEMBER: save anything custom you have in there first)
    Install the essentials so you can load G8F, then apply the pose; there should be no issues. Then you install items a few at a time, and check.
    Close studio down during install.
    Post edited by nicstt on
    edited June 2018
    I was not offended, it's simply against the TOS.
    So there's no morph listed at all under "currently used"?
    Post edited by Leana on
