How do I unzip multiple zip files in multiple folders
Xyetzt
How do I unzip multple zip files found in multiple folders but all folders are in the same folder?
basically this is the layout
folder/some number/Files/ *.zip
folder/some other number/Files/*.zip
folder/Yet another random number/Files/*.zip
folder/Hopefully you get the idea/Files/*.zip
Once upon a time there was a software that could do it but it got discontinued. Is there another way I can do this without going through all the folders?
edit: I forgot to say that it was not four folders but over two hundred. o.0
Post edited by Xyetzt on
If you are on a Unix based system such as Mac or Linux you could just do something like the following.
This will recursively look in all subfolders in "/path/to/zips/" and then extract any zip archives it finds into "path/to/location/where/extracted/"
I do not do windows but what you will want to use for that is 7zip which is free/open-source and create a bat script. I would not be much help to you with bat scripts as I have not used windows in years but this link may help you in creating one. https://superuser.com/questions/371384/extract-all-zips-in-a-directory-incl-subfolders-with-a-bat-file-or-dos-comm
Hope this helps.
