Renders are go from good to bad
Hi Everyone
I have a problem with my renders, it went from good to bad then to ugly with in a matter of weeks. Has this happen to anyone else, if so, how did you fix the problem?  Need help badly, I posted three renders with good bad & ugly on them
Thanks for your time
720 x 800 - 469K
1280 x 1360 - 250K
1280 x 1360 - 169K
  • Richard HaseltineRichard Haseltine Posts: 111,363
    it looks as if you have Depth of Field set to On in yoru camera settings. Select the Camera and check the Editor tab of the Parameters or Camera pane.
  • dakwolf60dakwolf60 Posts: 12
    I have looked every were in DAZ and can't fine what you are talking about
    I had to add a camera to find what you was saying, no it off. Thank you I found some of the problem and its fixed for now, till it happens again. promblem with my laptop
    thanks
    ok since I got you on line, how do I fix the color to my products. their tint is off and dosen't look right.
    I'm not good at spotting colour issues. What are you wanting to change?
    sorry went off line, my products, actors are losing their tint when I render them. their eyes go blank and the skin gose gray.
    its not all of them just a few.
    edited June 2018
    Well, the final colcour is a mix of the base colour, SSS colour elements (the light that enters and is scattered by the "skin", the glossy colours, and several other things - most of which the texture shaded preview won't even attempt to show. Light colour is also, of course, a factor. That doesn't tell you which things to look at, but you can experiment with the skin settings in the Surfaces pane, the light colour, and possibly the saturation and so on settings in Render Settings (the light and render factors woulf affect everything, but may be exaggerating the surface factors). There are several store products that will adjust the surface settings, and there's a long (and at times technical) thread on Iray skin https://www.daz3d.com/forums/discussion/54239/fiddling-with-iray-skin-settings
