Using the Wormbeast in Poser11.
This is my first attempt at using a DSON to use a character in Poser. I managed to get DSON to load, and the character shows up in my runtime. However the character is not visible after it is loaded into Poser. I ran through all the DSON pages and everything is about Genesis.
https://www.daz3d.com/wormbeast
There was nothing in the Wormbeast page about having to use Genesis, so the obvious question is, do I have to have Genesis to use the Wormbeast character?
I have used Poser for 15 years and would like to try out some of the DAZ characters that are not properly "Posered", so any help would be apreciated.
  • ChoholeChohole Posts: 28,904
    edited June 2
    Did you install both the DSON file and the PCF  (Poser Companion Files)
    The readme file is here, if that is any help    http://docs.daz3d.com/doku.php/public/read_me/index/23092/start
    The PAs official Commercialthread is here   https://www.daz3d.com/forums/discussion/63041/wormbeast-finally/p1    There may be some help in there.
    Post edited by Chohole on
  • None of the read me files have helped.
    Did I load the files? I think so, but DAZ puts things putside the Runtime folders that might be needed. I may have to attempt to let the DAZ downloader install everything. It could also be my ignorance on how the scripts work.
    I'm still working on it.
  • Finally got it figured out. I missed the part about adding the DAZ Runtime to my library's. But that required the DAZ importer which I never used because I tend to remove and the junk from the ZIP files.
    I'm glad you got it sorted out.
  • The Wormbeast is a fun figure. If only the inside of the throat had depth to the textures.
