Geometry Shell unparent
I can create a geometry shell around a figure. But I want to unparent the shell and delete the original figure. Unfortunately this also causes my shell to disappear (even after I unparent). Is there a way to achieve this or do I just need to keep the orig figure around and hide it?
  • kaotkblisskaotkbliss Posts: 2,918
    You might be able to export it as an object, then reimport it. Then delete the original figure
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,922
    the shell is actually the same as the figure just offset so you can convert the figure to a prop under edit rigging and use that.
  • TooncesToonces Posts: 919
    Thanks for the suggestions!
    Not really.  You can set the offset of the shell around the figure and it expands/contracts equally across the surface.  Creating a copy of the figure and converting it to a prop, or exporting an OBJ you get an object that scales from the origin, so you can't really get that relative-to-the-surface offset.
    Please let me know if I'm wrong here; and if there is a way to get the prop-of-the-figure to offset relative to the figure's shape.
    Ideally, I would also like to be able to convert the shell to an in independant object after setting the offset, but I'm having not luck with that.
  • Nevermind; I was able to accomplish what I needed by creating a copy of the figure and using a push modifier, sending that to Hexagon for merging/editing for the effects I wanted.  Now, someone needs to create a tool or script that will "Delete all non-visible surface polygons" or "delete all polygons within the perimeter of another closed object".  :D  I can't get boolean to do this exactly as needed.
