Applying Shaders
I'm embarrassed to ask this. Normally I'd just hop over to Google or Youtube, but my net is so slow tonight I can't load any videos.
Anyway. I bought a set of magic effects. It came with props, materials, and shaders. Props and materials I know how to use -- load the prop in the scene, then double-click on the desired material for the look. That all works fine. I'm running Studio 4.10.
But this came with shaders, which I've never used before. I load my prop, apply a material. I assumed that I applied shaders the same way -- i.e., double click on the shader I want while the prop is selected. I do that, it appears to load. I get no errors.
But when I render, nothing changes even after I've changed the shader. Or if it does, it's too subtle for me to see (I'm a bit color-blind).
So -- am I applying the shader correctly, or is there another method I should be using?
Thanks so much!
  • carrie58carrie58 Posts: 4,179
    you need to also go into the surface tab and click on the prop there too then apply the shader
  • franktuttlefranktuttle Posts: 67
    Thanks, Carrie58! That helped.
    my pleasure
  • Richard HaseltineRichard Haseltine Posts: 112,119
    The Surface Selection Tool will select both object and surface in one click.
  • AkuraAkura Posts: 41
    thank you thank you : O i been trying so hard to get my shaders to work ^^
  • CenobiteCenobite Posts: 206
    I usually just go to smart tab select the shader then merge too the suface panel you have selected, in most cases this works but there are a few bad packs that what the OP is saying makes sense they just don't work if applied.. Some texture shaders or mats are for specific mesh models & can't be used elsewhere.
