Fit hdri in a room tool
Getting hdris into a room so the walls don't block it is very confusing thats why I want a product that lets you scale the hdri more easily kinda like IBL master but for rooms.
  • Griffin AvidGriffin Avid Posts: 3,888
    This is a new one. Why do you want to get the HDRI small enough to fit in a room?
    So, you're trying to make an indoor shot that uses the outside sun's lighting?
    Wouldn't that be the equivalent of making a wall transparent or not seen?
  • IllidanstormIllidanstorm Posts: 655
    edited May 2018
    Yes I want to have HDRI lighning in a room.
    You can make the walls transperant but when the character stands in a corner then its not possible.
    Also sometimes walls can't be removed easily for example when they have a single prop for all the walls, a single texture for all walls or multiple layer walls if it's with a window and inside and outside wall texture
    Post edited by Illidanstorm on
    Have you thought about adding lights inside the room, itself?
    https://www.daz3d.com/iray-light-probe-kit
    The times where I put ghost lights inside a room are over for me. It takes way to long and it also makes people luck dull.
    The best thing I've found so far is the iray camera https://heroineadventures.deviantart.com/art/Iray-interior-camera-for-DAZ3D-Version-1-1-728244344 . It's nice but having it inside the room would be perfect.
    I'm not looking for a solution, I want someone to make this product.
