Morphs++ install problems--HELP! Please!
Raiden1423
I am at my fajljsf point right about now. I have been using DAZ for almost two years now and have never had a problem with installing anything until the recent download installer came about. Just about an hour ago I finally broke down and bought the M4 Morphs++ and tried to install it and the installer will not do a thing. It says it is installed, but when I try to use the morphs, nothing is there. I tried doing it manually--nothing. I tried to do the manifest file as I usually do, and it keeps saying it cannot find the file and that I need to find another program to use with it. I have NO idea what program.
Fifteen bucks might not be much to many people, but to me, that was a lot to pay for something that I cannot even use. I am irritated, I cannot find ANYTHING online that helps and I just...want...to get it to work. Please...please...PLEASE...help me. I have absolutely no idea what to do with it anymore. The morphs don't show up and neither do half of the things that people have suggested on other forums with similar topics.
The Moprhs++ package for M4, MUST be installed into the same runtime folder as M4 is installed to, it cannot be installed into a different folder. Find out where DIM installed M4 to, or if you installed it yourself, find the runtime folder you put it into, and install Morphs++ there, it will not work otherwise.
If you have installed content using DIM, and you want to see what has been installed, and to where, it is very easy to do. Click on the 'Installed' tab, click on the item that you want to know about, right-click on it, and then select Installed Files. A new window will appear, and at the top, it tells you what library folder it was installed to, and underneath, every file that it installed and the install path.
