genesis 2 basic female DMC
WendyLuvsCatz
I did it!!!
https://www.box.com/s/d1r80eqay3d1sb6ti960
uploaded to sharecg too
http://www.ShareCG.com/v/69954/view/11/Poser/Daz-Genesis-2-Basic-Female-DMC
Have you tried every DMC file that you have?
I don't have Genesis2, but having about 57 DMC files, I have noticed in the past that
sometimes a DMC file that you would not expect, will give a reasonable result.
yes but she has a rigged jaw which in itself changes the way she uses facial morphs.
I used this addition allocating visemes in iClone 3dxchange expression editor
in Carrara I will save NLA clips which match the default ones and kit bash the rest then allocate them to the visemes in the Carrara mimic plugin.
you do not need a Poser format cr2 to reference like you do in mimic pro, one reason I have never quite figured out mimic pro.
I have to literally create new cr2's for any figures that do not have .dmc and mimic compatible versions and mine NEVER work!
So many figures have viseme morphs but none of the other figure's configuration files work on them either so one needs to start from scratch and I just inspite of so many good tutorials never been able to do this in mimic pro standalone.
G2BF looks like one of those so far, I tried a few.
thank you
http://youtu.be/XJ5olV-uP9Q
Thank you. I already tried this and it looks good. But it shows me this message:
"Some channels defined in the current configuration file could not be found on the figure. Lipsynching may not be as acurrate as expected."
What's wrong? I see that the character's mouth moves correctly....
no idea am new to this myself, did it as I needed it so sharing
if it works should be no problem
This will work well for "Genesis Male 2"?
yes it does
I can not seem to find it anywhere, all links seem to be broken
you no longer need it, DAZ supplied one of their own long ago, I made the file that was here before there was one
this is an old thread
it will be in your library under general mimic configurations
