Decimator
Hello
I own DAZ Studio 3 and decimator
I reduced a Victoria model up to 20k tris
I converted it to FBX file
Then I exported it to Unity3d
Unity claims that the numbers of tris is still higher than 65.000
however animations are quite fluid
did anybody have the same issue ?
PS
Any news for decimator in DAZ 4.5 ?
  • DAZ_bfurnerDAZ_bfurner Posts: 62
    Decimator works for 4.5 as long as you have the Serial Number for purchasing it.
    If you are using the Decimator for previous versions, that SN should work for 4.5
  • hOsshOss Posts: 24
    The tri count in Unity is based on a number of things other than just raw triangles. It considers the triangle, each material assigned to a vertice increases it's count (Shaders need to draw the vertice once for each material) as well as UV assignment ( if a vertice is on a UV seam, each UV island it's a part of counts as an extra "draw", increasing its "count."
    Check out this video:
    http://lesterbanks.com/2011/04/quicktip-vertices-unity-uvs-whats-the-deal/
    -Patrick
  • edited December 1969
    thanks
    I have the serial number for decimator
    I thought that decinator does not work well ith 4.5
    am i wrong ?
    -Patrick
    Thanks a lot
    Yes it make sense , actually I reduced the number of tris with decimator but I di not use Texture atlas
  • Richard HaseltineRichard Haseltine Posts: 112,268
    The Decimator plugin works in DS4, but requires a non-free serial number for activation - either from a paid-for copy of DS4Pro or from a separate Decimator license.
