DSON Not Working
So I installed DSON but it doesn't say it is installed and it doesn't show up when I'm in Poser.
1331 x 651 - 115K
  • The DSON Importer does depend on the correct path being set - if you right-click on its entry in DIM, select Show Installed files, and click on the base path at the top does it go to the Poser application folder?
  • WandWWandW Posts: 2,910
    Where is it not showing up in Poser?  If it is installed, there should be a folder called DSON Support in the Scripts menu.  Otherwise, it functions transparently if your DAZ content is installed to a folder in the Poser Library.
    PS; make sure you grab the Late D3D's DSON loader script, which can load many DSON items that do not include Poser Companion Files...
    http://d3d.sesseler.de/index.php?software=poserpython&product=dson_loader
