V4++ morphs question
I just bought the V4++ package. Do you not get the individual folders now, ie - just have to load them all?
thanks,
mystmaiden
thanks,
mystmaiden
When you load V4 in your scene you will be prompt whether or not you want to check them on as added-on dial morphs.
When you load V4, you should get the PowerLoader popup asking you which morph packs you want to load. If you'd rather load each morph 1 by 1, you can find them under Poser Format > My Library > Pose.
Thank you both for the replies. I forgot to add that I am using Poser 7. I'm not seeing all the individual poses, so maybe I didn't dl the right packages,,,
What I do have under poses is a folder called 'base' with some expressions, eye poses, some heads, etc
In Poser 7, the individual morphs are in a folder named morphs ++. You should have installed ps_pe070 v4morphs.exe. The file path in Vista is C: Program files/e frontier/Poser 7. You will be asked to initialize. Click Ok.
The individual morphs ++ should be located Poses
Click thumbnails to select desired morphs to inject into V4 figure.
Thank you, Pixel8ted! The screenshots helped a lot. I reinstalled the file and its all sorted now. I'm not sure it I missed installing it on the first go or if it just had a hiccup somehow.
thanks again all,
mystmaiden
No problem. When things don't show up as they should, I usually manually go through the e frontier poser 7 application folder to look if there is a secondary runtime folder added where it shouldn't be...usually in the library folder. If there is a secondary runtime folder, I move it to where it should be.
