how do i do a scene outside window
tn222ebtn222eb Posts: 34
edited February 2018 in New Users
hi every1
my problem is that outside window all i see grey
how do i do get the view outside the windows like these pictures(found them on the internet) or whats the products name
1000 x 563 - 139K
1280 x 720 - 298K
1920 x 1080 - 476K
1920 x 1080 - 569K
Post edited by tn222eb on
  • MarcCCTxMarcCCTx Posts: 948
    Easiest is fake wall with window. Otherwise you need lighting inside and out, and make sure you don't have too much light reflecting into the camera.
    Post edited by MarcCCTx on
    i think you misunderstanding my post, i wonder how i make the view outside the window like the example pics i borrowed from google where you see buildings etc
    I think what he is trying to say is that you need to put an image outside the window loaded onto a plane, to make a false wall which has the scene on it.
    ah ok ill try it, thx
    Here's an example of that https://www.daz3d.com/apartment-39
  • gederixgederix Posts: 392
    Ibl can also work for outside the window scenery.
  • tn222ebtn222eb Posts: 34
    is there a way to make a realistic backdrop
    whats lbl
    Basically it's a wrap around image that also lights the scene based on the light sources of the image. While not physically in the scene, it is rendered no matter which way you look and creates a very realistic light. For example from https://www.daz3d.com/ultrahd-iray-hdri-with-dof-seaside-resort.
    The light would come from the brighter spots. and if you set up a room from the window it would show you whatever would be seen in that direction. Basically it is mapped to a globe surrounding your scene. Usually Iray.
    Edit: Image based lighting
    400 x 400 - 174K
    The real problem comes when you want different lighting inside and out. You have to seal the room from external light (except what is coming from windows.) So you cant use a lot of the sets from DAZ which are open on one end.
  • FishtalesFishtales Posts: 6,238
    You can, all you need to do is place a Plane across the opening blocking it up.
    Yes, but a lot of the older sets (ex: The Study)  leak light at the joints. Your mileage may vary.
  • jag11jag11 Posts: 885
    For similar scenes just make sure glasses are thin and keep tone mapping linear.
  • thx all for the tips
    do you guys have any suggestions of good hdris/image/products i could use to load on the plane
    This is a good place to start:
    http://www.hdrlabs.com/sibl/archive.html
    thx
