Giselle 6 texture for Genesis 8 female
Hello. I'm trying to use Giselle 6 texture for Genesis 8 female character.
My first thought was to use this product, but it won't work because Giselle 6 has custom UV set, different from Genesis 2.
https://www.daz3d.com/legacy-uvs-for-genesis-8-genesis-2-female
Secondly, I tried to edit textures in gimp and "merge in" Giselle 6 texture on Genesis 8 one. However UV differences are too strong and result wasn't good (mainly lips are all wrong).
Does anyone have any recommendation how to achieve this? Thank you for all your comments.
  • 3Diva3Diva Posts: 12,058
    I think there might be a way to do it with something like the Map Transfer utility. Transfer the Giselle 6 textures to the base Genesis 2 female via the Map Transfer and then use the Legacy UVs product.
    I don't know how to do it - though I do vaguely recall seeing a tutorial on how to do it here on the forum. Maybe someone who knows how to do it can chime in and point you to a tutorial. :)
  • xyer0xyer0 Posts: 6,505
    And once you get Giselle 6 into Genesis 2 UV, use the Iray convertor included with the Genesis 2 Female Starter Essentials, which generally does the most accurate conversion. Then save it so you can use it for G8F.
  • Thank you everyone! And thank you again Cayman for product.
