Fault export of animation from DS to MD
Hi, guys! Could you help me solve the problem.
I'm trying to export animation (transition from T to Ф pose) from DS to MD. I'm using Collada.
Avatar - Genesis 8 Male.
But after import in MD I get this ....see attachment =)
Regards,
Anton
  • Please repost your image without textures in the MD window? Which version of Marvellous Designer is that?
  • antondermakovantondermakov Posts: 10
    edited January 2018
    Ok. I use MD 6.5 (3.1.38 r25775)
    This happened only if I use genesis 8. if I use genesis 3 - it works.
    1920 x 1080 - 561K
    1920 x 1080 - 538K
    Post edited by antondermakov on
  • TheKDTheKD Posts: 2,711
    If you have MDD export, that works really well. I export obj and MDD animation usually, then export back obj sequence to get it back into studio.
    Does it works with genesis 8 ? I get fault when try export in MDD. =(
    You get some kind of error during export? Yeah, it exports fine here in MDD, hmmmm.
  • I get this error if I try to export in MDD. (with genesis 3 and 8)
    1920 x 1080 - 318K
  • MDD requires the full version of the AniMate 2 plug-in.
    Ah crap, I forgot that the MMD export was part of the animate 2 pro version :(
    Pretty steep price unless you feel you are going to get some use from the rest the package offers.
  • Should I buy this package https://www.daz3d.com/animate2 ?
  • Hi to all!
    I'm trying to export genesis 3 male model with animations from daz3d to MD. I used muscularity hd for male and it require hqsubdiv for more details. But if I export by .collada then model reduce subdiv to 0.
    How can I solve this problem?
  • Fine! Yes! AniMATE2 works! Thank you!
    SOLVED =)
  • Cris PalominoCris Palomino Posts: 12,963
    You shouldn't need details for MD, just the mass.
    Merged threads as they appear to be on the same topic.
  • You shouldn't need details for MD, just the mass.
    Maybe I know, what I want? =)  I need details, because I simulate HQ clothes and I need all folds. I want see muscularity through clothes.
    And you merged it in one thread but it is different problems.
  • MDD might work, since that's a vertex cache. Collada (and FBX) export the SubD cage - what's called the base resolution in DS - and expect SubD to be reapplied in the destination application (and presumably expect multi-resolution morphs to be reconstructed).
