Repeat image for textures
Hello,
This is probably quite simple but i can't fund the option.
I want to apply an image to a primitive object so that it repeats, rather than the image being stretched to fit the size of the object. where do I select this option?
Thanks
Richard
You need to look the Vertical and Horizontal tile options. In DS it is in Surface tab (select surface of the area you want to apply the image) - usually almost at the bottom. Input the number higher than 1 to have multiple repeats. In some DS versions vertical tile and offset might not work correctly.
Thanks for that. I did actually look at that yesterday when looking to see if there was just a repeat option to select. I just set the tiling to 20 instead of 1 and does the job. Works better really. Thanks for your help. :)
Richard
You are welcome :)
