This old man needs help
johnnvjohnnv Posts: 0
edited May 2013 in The Commons
Which files(s) to download if I’m using studio 3.1.2.24 and I don’t use the install manager? I see on my download page the following files:
689 x 421 - 59K
Post edited by johnnv on
  • frank0314frank0314 Posts: 15,120
    edited May 2013
    Your photo isn't showing. Try attaching the photo to your post instead of imbedding it in the text. You should see an upload box that allows you to add one.
    Post edited by frank0314 on
    You need to download item four on your list, if you want the EXE installer for windows, or the one below if you want the ZIP file for Mac users.
    If you were to use the DIM, then it would make things much simpler for you, you can set a filter to download the DS3 version only, or Poser and DS3 only, or various combinations. You don't need to install using the DIM, but it can be very quick to use to download ZIP files, and store them for you.
  • BlackFeather1973BlackFeather1973 Posts: 739
    edited May 2013
    JimmyC_2009 usually knows better than me, but i do think the fourth item is triax wich can't be read be DS3.
    My money is on "15009_ClrsPhillyHair_v1.1_dpc.exe" for windows and "15009_ClrsPhillyHair_v1.1_dpc.zip" for mac.
    Edit : Sorry, my keyboard was faster than my brain again., they are materials wich can't be triax, so JimmyC_2009 did indeed know better than me :cheese:
    Post edited by BlackFeather1973 on
