Do zBrush displacement maps just take effect at renders ? & not Posing.
RorrKonnRorrKonn Posts: 509
edited May 2013 in The Commons
Say you have a mesh with a displacement map and your posing the mesh.
Will the displacement maps slow you down while your posing the mesh ?
I'm asking for DAZ Studio
Thanks
Post edited by RorrKonn on
  • KatteyKattey Posts: 2,899
    edited May 2013
    Thanks
    In DS default view displacement won't render in any way so it shouldn't slow you down.
    In ZBrush itself they might, but with the other hand, ZBrush can render millions of polygons.
    Post edited by Kattey on
  • Zev0Zev0 Posts: 7,123
    edited May 2013
    Displacements only appear at render times. Be it made from Zbrush or any other source.
    Post edited by Zev0 on
  • RorrKonnRorrKonn Posts: 509
    Is there a limit to how many polygon's a displacement map can have ?
    Thanks
  • frank0314frank0314 Posts: 15,101
    You can do displacement in zBrush at 1mil poly and apply that map to a 5k model and it will be pretty close.
    Also remember that the Displacements must be saved when the base mesh is at Sub-D level0 in zbrush. The detail will all be there even at base.
    edited May 2013
    As I'm modeling ,I keep on thinking of stuff I'm not sure of.
    If I have a real low polycount mesh that's barely looks human,just a canvas for the displacement map.
    Then add a lot of detail with the displacement map.
    When I pose the mesh or have a extreme facial expression say him screaming with his mouth wide open.
    Will the displacement map still look good ?
    Thanks
    Thanks for the tips
    edited May 2013
    All depends how the mesh reacts to expressions and where the Displacement details lie. The two have to work together. You cannot just add displacement detail and hope for the best. See how it reacts to a certain bend etc, and make adjustments from there. So yes all the displacement detail will be there, but will it flow with the mesh is another story all together.
