Liquid pack shaders...
I got the liquid pack with various props including blood props and blood color shader, but after opening the prop how do i add the color shade?
I select the prop and double click on the shader but the color never changes, how do i make it red?
  • Are you refering to this: https://www.daz3d.com/liquid-pack
    If so, what renderer are you using? I think the shaders in that pack may only be for 3DL.
  • Oh, is there another liquid or blood pack i can use for the nvidia iray?
  • Charlie JudgeCharlie Judge Posts: 13,628
    edited December 2017
    You could still use the props from your original Liquid Pack and then apply one of these shaders for Iray:https://www.daz3d.com/iray-liquid-shaders . Since you are a PC+ member they are not very expensive.
    ETA: There are also these packs for Iray:
    https://www.daz3d.com/rigged-water-iray
    https://www.daz3d.com/rigged-water-iray-2
    Post edited by Charlie Judge on
  • I got the iray liquid shaders, but when i try to apply them to the liquid pack props, is still won't turn red.
    Can i use the iray shaders with the liquid pack props?
    that's the liquid pack
    They should apply OK. Here is a quick Iray render of the splatter prop from the liquid pack with the blood shader from the Iray Liquid Shaders applied:
    968 x 614 - 60K
  • HoMartHoMart Posts: 489
    To aply a shader to a prop you need to select the surface you want to aply it to in the surfaces tab
  • Not working for me either
  • I got the liquid pack with various props including blood props and blood color shader, but after opening the prop how do i add the color shade?
    Not working for me either.
  • I have the same problem. The shaders do nothing. If I use a shader, nothing happens. also If I load a blood prop it it has no shaders only the prop is loading  without texture
  • Are you rendering in Iray (the default) or 3Delight? Given its  age and that it doesn't mention Iray I would think this uses special 3Delight shaders which will not auto-convert to Iray (though you could use some of the Iray liquid shader presets on the props if you select them and their surfces, e.g. by clicking on them with the Surface Selection tool.
  • thank you for the answer.
    yes, i am rendering in Iray. I will give it a try
  • and it worked with the surface tool.
    thanks four the fast help
