Released!-Lillyanna for Genesis 8 Female and Expansion Pack (Commercial)
DarwinsMishapDarwinsMishap Posts: 4,074
edited December 2017 in Daz PA Commercial Products
She's live!
https://www.daz3d.com/lillyanna-for-genesis-8-female
https://www.daz3d.com/lillyanna-expansion-for-genesis-8-female
Lillyanna is a Sicilian-based character for your library needs.
Her head is a custom morph, as is the body and nail morphs and need no additional morph packs for use.
Her skin is a mix of Merchant Resources and Photo Resources and includes a lower torso tattoo, an inner wrist watercolor-styled colored tattoo, an upper arm tattoo, and a hip Black Widow Spider tattoo that I've also moved to a shoulder for an additional option of use.
Lillyanna has 5 complete Eye Materials, 3 Lash Materials with 2 color options, a Mono-SSS shader that can be used if the Chromatic Shader system that the Eye Materials use creates render artifacts, base Finger and Toe Nail Materials with 5 Nail colors. There are 3 Brow options as well as the usual No Brow Option for her, too! You never know when you want to use mesh brows.
Her make up utilizes the LIE Material System; however, the Lip Colors are saved with a ring of her facial skin, so they should only be used with her Skin set. The 2 Blush, 5 Eyeliners, and 6 Eye Shadows can be used on any Genesis 8 Female figure.
I've included the Base Skin Gloss Setting, as well as a Low/High Gloss Setting option for use with different lighting rigs and HDRI Environment map systems.
Anatomical Elements are included.
Materials are Iray only.
Her Expansion Pack turns her into my version of a kid between the age of 11-13.  Required is Zev0's Growing Up for Genesis8 Female pack, alothough I re-morphed the Adult head a bit more for the Child version as a base for Zev0's pack to work, as well as the Lillyanna base is required to use the Expansion Pack.  Included in the Expansion pack is the same skin/eye/lash Material Presets and another Torso texture set, as well as an additional 5 Toe and Fingernail polish options.
1000 x 1300 - 1M
1000 x 1300 - 1M
1500 x 927 - 1M
1500 x 927 - 1M
1500 x 927 - 1M
1000 x 1300 - 1M
1000 x 1300 - 936K
1000 x 1300 - 2M
1000 x 1300 - 1M
Post edited by DarwinsMishap on
