problema con 4.5 pro qualcuno puo' aiutarmi in italiano
fabio.carafafabio.carafa Posts: 0
"Victoria 5" has a dependency on another product and the required file(s) could not be found in the chosen location.
Please choose a different install location.
    Victoria 5 is a morph of the Genesis figure, and need to be installed into the same folder as Genesis.
    Where do you have Genesis installed to? Where are you trying to install V5 to?
  • fabio.carafafabio.carafa Posts: 0
    excuse my English. I try to install v5 in user / fabio / documents / daz / studio / my library
    thanks in advance for your response to my question
    Where is Genesis installed to? Is it installed to the same library?
    Did you install Genesis Starter Essentials? If not, you wont have the base Genesis figure.
  • Scott LivingstonScott Livingston Posts: 4,352
    Dove è installata la figura Genesis? È necessario installare Victoria 5 nella stessa cartella (directory). Se l'errore continua ad apparire ... che versione di "Genesis Starter Essentials" è installato, e quale versione di Victoria 5?
    (Auto-translated. .. posso capire un po 'di italiano, ma non mi ricordo come parlare italiano!)
    edited May 2013
    If you haven't installed Genesis, you can find "Genesis Starter Essentials" in: My Account>Product Library (http://www.daz3d.com/downloader/customer/files/)
    Se non avete installato Genesis, è possibile trovare "Genesis Starter Essentials" a: My Account>Product Library (http://www.daz3d.com/downloader/customer/files/)
    Post edited by Scott Livingston on
    sorry but I did not understand that I need to install folder. daz genesis? genesis? or morph
    I installed daz studio pro 4.5 + + genesis genesis starter essentials cf poser + pro v5 bundle
    Figure genesis is installed in document/daz3d/studio/mylibrary/runtime/charapter/dazpeople.
    I tried to install v5 on that path but always gives me error
    edited May 2013
    Try installing V5 to "My Library." (document/daz3d/studio/mylibrary)
  • MusclemanMuscleman Posts: 3,102
    edited May 2013
    Ciao Fabio, c'è un topic dove parliamo tutti italiano se ti serve :) cmq. Per usare Victoria5 DEVI prima avere DazStudio con genesis installata e non istallare Victoria5 manualmente fiati, ma è meglio che lasci fare al DIM ( Download istall menager) da poco rilasciato da DAZ che trovi qui>>>
    http://www.daz3d.com/install-manager-info
    che ti installa tutto dov'è giusto che sai in modo semplice e veloce:) basta che ciò che vuoi instalalre sia nel tuo accoaunt e comrpato qui su DAZ store :)
    se haia ltri dubbi, non esitare a contattarmi :)
    Post edited by Muscleman on
    I do not understand I tried also ...... daz my library / people / genesi...ma does not install always tells me to choose another path
    ti ho risposto io....
    ti ringrazio moltissimo per l'informazione. ma non capisco cosa vuol dire devo avere daz studio e genesi. io ho daz studio 4.5 pro e genesi essent...ecc non vanno bene?
    perfetto :) ora devi solo scaricare e installare nel tuo PC il download menager ( vedi il linksopra, e dal tuo account via download menager, scarichi e installi victoria5
    grazie mille ora provo...ciao e grazie ancora
