Adjusting th e push modifier
How does one adjust the amount of "push" in the push modifier? I can select the clothing item, and then when I select the push modifier, the item ends up a larger distance from the surface of genesis than desired.
After you apply a push modifier, a new entry will appear in the parameters tab called mesh offset. The default is 1.0 which is usually way too high. Try setting it to about .2
Units are cm, right? So .2 is 2mm?
Yes.
I was abke to use the tool easily. Thanks - it went fine.
You are right - the 1.0 setting is way off. I went down to .5
