How can I save an assymetrical face made with PowerPose?
I have created a G8M face and used PowerPose to create some asymmetry with the facial bones.  I wanted to save a "zero" expression preset with these settings so that if I zero out the character I don't lose the asymmetry.  However, both the Pose Preset and the Shaping Preset for the head only do not include G8M's extra facial bones, just the basic G8M morphs.
Are the face bones saved under Hidden?
I only want to save out the face in case I want to zero the expression, without changing the pose.  The expression is the last thing I work on.
How can I do this?
  • carrie58carrie58 Posts: 4,171
    dracorn I would try saving as a Pose preset ,expand all , uncheck everything but the head and all the bones in it ,then save only modified , but save your original first as a scene subset so if that doesn't work you can try again .....there's lots of facial bones once you expand the tree ... hope this helps
  • 3Diva3Diva Posts: 12,058
    Perhaps export it as an OBJ and then reimport it and save it as a morph?
  • dracorndracorn Posts: 2,379
    Thanks for your suggestions.
    carrie58, OK, let me try that.
    Divamakeup - will I loose functinality that way?
