Daz could not find the Genesis texture!
DS could not find the Genesis texture!
Hi guys! It is so strange that I just used it yesterday and it worked perfectly fine, but this morning after I manually installed another Genesis 8 male bundle, DS could not find the textures. I checked the folder, as you see in the screenshot, everything is there. How do I link the texture? or there is another way to solve it?
2177 x 1212 - 791K
The "Content" folder at the top of the path is suspicious - is that your content directory, or is it a folder inside your content directory?
It is my content directory, this folder is just under My Library.
You should not have both My Library and My Library/Content, assumign My Library is set as the content diectory (which it will be by default). Usually everything you have in Content should be in My Library, though moving and merging may be a fiddle on a Mac.
Thank you! It works right now!
