G8M Eyelashes Not Following Custom Head Morph
Gregorius
I've developed a custom head morph for Genesis 8 Male. I originally sculpted it on Genesis 8 Female with a male base morph applied (because I only have merchant resources for the G8F base), but I've successfully transferred the morph to G8M. The morph on G8M itself works just fine. The problem is that I can't get the male conforming eyelashes to follow the new morph. Any help will be greatly appreciated! Thanks in advance!
Have you saved your morph as a morph asset? Also make sure autofollow is checked in the morph's parameters. I think you need to save the morph and reload before the lashes with autofollow correctly.
Yep, I saved it as a morph asset, and I at least thought auto-follow was checked. A bit more experimenting did the trick. It turns out that you have to check auto-follow before saving the morph. I was trying to edit that setting after the fact, which wasn't working for some reason. Thanks!
