recursive functions
Question 1: I'm trying to create a recursive function that will start at a parent node and work its way through the children, printing out their assetId, but it only returns the first child in each instance.
function GetChildren(oNode){ ChildrenNode=oNode.getNodeChildren(); if (ChildrenNode!=null) { for ( i = 0; i < ChildrenNode.length; i++ ) { print("num "+i+" Length"+ChildrenNode.length+' Parent: '+oNode.assetId+' Child: '+ChildrenNode[i].assetId); GetChildren(ChildrenNode[i]); } }} GetChildren(Scene.getPrimarySelection());If I start with the following parent child structure:
Square
-childSquare1
--Grandchild1
--Grandchild2
-childSquare2
It will only return (-childSquare1, --Grandchild1 )
Any idea what I'm doing wrong?
Question 2: how do I also return the node's label name, and not just its assetId name? *Edit* I figured this one out- have to use .getLabel().
Post edited by BradCarsten on
Your reasoning was right, but the lack of "var" confuses the scripting engine. To avoid this pitfall always declare variables first, immediatly after the '{' character.
aaah, that works perfectly. Thanks so much jag11. you wont believe how long I sat on that.
