DECAL!
It has been like since 15 years since I did a DECAL on an object and cant recall how? I have an object which I want to put what will look like screen printed TEXT in one side of an object..
1) How do i do that again?
2) Can I have a TRANSPARENCY on this DECAL so its just the letters that appear to be on the object?
  • 3DAGE3DAGE Posts: 3,321
    HI Richard :)
    Layers. :)
    create your shader for your model,.. go to the shader room.. View the model in the shader preview window,. then go to the top of the screen
    you'll see a set of Layer tools to create a shape layer,.. and a pointer to adjust the layer.
    When you draw the layer directly onto the model in the shader preview window,. it will create a new Layer in your original shader.
    so,.. you can then add a texture map and an alpha map, or you can use a PNG, or PSD which has transparency.
  • edited December 1969
    A Video Tutorial about Decal-Shading
    Good luck
    Geli
    I have experimented with all this and i have a CUDE I was trying to Paste a DECAL on one side and its distorted its PINCHED in the middle?
    Can you adjust to AREA once you put it on your object
  • cripemancripeman Posts: 63
    hey rich...I have a graffitti tutorial that covers this...and yes you can adjust the area.
    http://www.youtube.com/watch?v=0M13rNo3XkA
