The Freebie Core Lighting 2
Griffin AvidGriffin Avid Posts: 3,882
edited August 2017 in The Commons
https://www.daz3d.com/core-lighting-2
I assume this will NOT work in iray and this is a light for 3Delight engine....?
Same with this..?
https://www.daz3d.com/portrait-lights
and..and
https://www.daz3d.com/lantios-nighttime-pack
Post edited by Griffin Avid on
    Yes those are all old 3delight sets I believe
    edited August 2017
    It's a maybe...if it uses 'standard'  (spots, points, etc) lights then they'll convert to photmetric 'automagically'.  But if it uses things like the Uber lights then no...or conversions will need to be done manually.
    The big thing, though, will be the tweaking of the levels needed to match between the two renderers.
    Additional
    I just down loaded the Core 2 set...and no, it can't directly be used as it is an 'environment' light with a dome...which pretty much will be a royal pain to use in Iray, directly.  BUT the maps used on that dome should work plugged in to Iray's built in dome.
    I'll give it a go in a few minutes and post a render or two.
    Post edited by mjc1016 on
    edited August 2017
    Yes, the tif versions of the maps work quite nicely in the Iray environment slot...
    800 x 640 - 231K
  • Griffin AvidGriffin Avid Posts: 3,882
    cool!
    I'm working on a set of Iray presets for this.  I'm setting up the dome and replacing the 'sun' with a photometric version.  I'm not trying to match levels exactly but I think I'm in the ballpark.  When finished, I'll put them up on ShareCG.
  • CybersoxCybersox Posts: 9,913
    That would be awesome!
    edited August 2017
    Here's a couple of the converted presets...numbers 1 and 10,
    This is a default M7 and the light preset, nothing else.
    I'll have them packed and uploaded sometime Thursday afternoon.
    512 x 512 - 226K
    512 x 512 - 212K
  • Thank you.
  • mmkdazmmkdaz Posts: 335
    Oh nice! Thank you for hte conversion!
  • dawnbladedawnblade Posts: 1,723
    Wow! Thanks @mjc1016.
  • Thank you mjc1016, very much appreciated.
    smiley
