Clothes no longer fit properly after Actor parameters adjustments
dtinc88
Hi All,
I have made numerous adjustments in Parameters to Blaire character (https://www.daz3d.com/blaire-for-genesis-3-female-s) over the course of the last couple of months. Some of the adjustments included blending-in other Genesis 3 characters' body features. After the adjustments were made, none of the Genesis 3 clothes that I had previously purchased fit the modified Blaire character. Everything now fits like a saran wrap (both, tops and bottoms). I have tried using Fit Control and Universal Breast Helper to no avail. The clothes just don't fit. Am I missing something here? If I am, please advise. This is super frustrating. Thanks in advance.
Not fit as in skin poking through the clothes, or not fit as in fit too well, losing the appearance of draping? Your text sounds like the latter.
the latter
That can be tricky to deal with - you are already trying the tools from SickleYield and Zev). Is therea a Smoothing Modifier applied to the clothes?
How do I check?
If I understand your question correctly, then no, neither Fit Control nor Universal Breast Helper are applied to clothing.
But you have tried using them?
A Smoothing Modifier will show by having a group in Parametrs labelled Mesh Smoothing.
Mesh Smoothing for clothing was off. I enabled Mesh Smoothing w/ Base Shape Matching and played with Smoothing Iterations and Collision Iterations. The clothes fit smoother but there is still that very pronounced saran wrap look.
I bumped up Smoothing Iterations to 50 (from 1) in Mesh Smoothing for clothes that was previously super clingy. I have also added Smoothing Modifier to Blaire character (Edit->Figure->Geometry->Add Smoothing Modifier). Looks infinitely better now.
I wouldn't put a Smoothing Modifier on the character as that will tend to remove details, unless that's what you want (you can remove an unwanted modifier from Edit>Figure>Geometry>Remove Smoothing Modifier).
ok, I'll remove it. Thanks.
