New library/base directory without sharing resources...
Frinkky
in The Commons
Hi,
I'm in the process of rebuilding my G3F installation and have created new library in order to install bits and pieces from the ground up. The idea is to trim the fat - I've a lot of custom morphs Ive created over time as well as freebies and the odd purchase. This has caused my default G3F install to be very slow to work with and most of the stuff I don't use.
The problem is specifying a new base directory, Daz does the clever thing of merging data folders - thus all old morphs load with the new install. So, is there a way to do this? A separate installation of Daz Studio with it's own settings would be ideal...
Thanks in advance!
Two thing I can think of is to have different themed libraries and move the morphs that fit the theme to the libraries, add or remove libraries depending on the project. Second is to have a project library with only what you need in it for the project
