How to crush hair so it doesn't poke through hats and other headgear
I can usually deal with poke-through in clothing, but I haven't figured out a way to eliminate hair poking through hats. Even fairly close-to-the-head hairs are likely to poke through what appears to be a fairly roomy hat. Bulky hairs are pretty much "Forget it."
I'm hoping there's a relatively simple way (i.e. short of learning Blender or something similar) to tuck hair under headgear. If so, I would really appreciate knowing what the trick is.
  • SimonJMSimonJM Posts: 6,100
    @Sickleyield has a helper product for each of Genesis 2 and Genesis 3
  • Blind OwlBlind Owl Posts: 504
    Now, how did I miss that? Thanks, SimonJM, it's going on my 'must buy' list. yes
  • chris-2599934chris-2599934 Posts: 1,975
    The Sickleyield products work pretty well, you could also try using deformers to push the hair under the hat.
    If all else fails, do two renders - one with hair and one without, then combine the two images in photoshop using the bald image to supply the top of the hat without the hair.
  • GoggerGogger Posts: 2,533
    EXACTLY!
    Sometimes I have the time to learn something new, sometimes I simply have to get the thing done. Photoshop usually bridges the gap between my rendering skills and the lack thereof.  I prefer to learn new things when I can though.
  • PetercatPetercat Posts: 2,324
    You can use the Geometry Editor tool to slice off the part of the hair that fits inside of the hat.
    edited August 2017
    Good suggestions, and cheaper than buying a fixer-upper (though I notice SickleYield's is on sale). I'll try them both today and see if they do the job.
    Thanks!
    Post edited by Blind Owl on
