G3 UVs for Genesis
Is there any way to use G3 textures on Genesis? I know it's possible to UV map older textures across to newer models but can it be done in reverse? I looked at Cayman's stuff, but they only do that with G2, G3 and G8. Nothing for Genesis, I assume there's a reason for this.
I have some nice Genesis morphs that I'd like to use with G3F and I thought I could get around that by using G3F textures on Genesis. Can it be done?
Thanks!
  • dracorndracorn Posts: 2,381
    You can use GenX2 with the G3 add on to transfer the Genesis morphs to G3F.  Note that you must get G2 as a bridge between G1 and G3.
    Or you can transfer manually with Redz' tutorials on this thread:
    https://www.daz3d.com/forums/discussion/176271/morphs-from-g3-to-g8/p1
    I personally prefer the GenX2 method because the script involves fewer steps and it creates tidy icons and places them where you specify.  Plus there is maintenance - you can rename and delete morphs as well.
    I have lots of G1 characters - they are some of the best.
