Transitional Shader?
CowrieCowrie Posts: 149
edited July 2017 in Daz Studio Discussion
Is it possible to have one shader blend into another in a sort of transitional area?  If so, how would one go about doing that?  Please and thank-you!
Post edited by Cowrie on
  • Richard HaseltineRichard Haseltine Posts: 111,915
    Do you mean over time or in a single frame, blending over height or depth for example? Iray or 3delight?
  • CowrieCowrie Posts: 149
    In a single frame over height or depth, and preferably in 3delight, though something Iray would also be welcome.
    The basic answer is to use the Shader Mixer - we actually recently discussed some aspects of what you want to do in this thread https://www.daz3d.com/forums/discussion/184811/shader-mixer-not-working-as-tutorials-explain
    edited July 2017
    Thanks, though I'm not sure if the fact that the one two different shaders has numerous image maps for stuff like bump and I also want those to transition requires a slightly different setup or not.  I'll give it a whirl as is and see how it works out.
    Update: I figured it out, setting up a mix brick for each of the different maps.  However, what would you use instead of or in addition to altitude if you wanted the gradient to go on the other axis?
