Beautiful Eyes for Genesis 8?
mikekmikek Posts: 195
So far eyes have been difficult for me to get right. Which genesis 8 female or packages do you prefer concerning eyes or which package produces the best eyes for you?
  • AndySAndyS Posts: 1,449
    None.
    Only "own" standards.
    See the example here (quite at the bottom of that page)
  • mikekmikek Posts: 195
    AndyS said:
    None.
    Does this work with genesis 8? After applying the pupil is white for me.
  • FauvistFauvist Posts: 2,290
    Can you switch the UV for the eyes to G1 or G2 or V4 - and then just apply one of those textures?
    edited July 2017
    Hm,
    no idea.
    Try this. And give her some Cornea Bulge and close the iris (Eyes Pupils Delate = -30%).
    We're talking about G8F?
    duf
    duf
    Eyes Reflection.duf
    39K
    Post edited by AndyS on
    Genesis 8 has for me only the base female available as UV. G3 textures seem to work although there have been changes to the eye geometry and I believe a material got merged. But eyes have always been a problem for me so I wonder what users here prefer or if they have something which works well for them.
    AndyS said:
    Hm,
    no idea.
    Yes its G8F and this one does work. Here is a comparsion of where I stand currently:
    Left to right are the base female, elizabeth, victoria and rebekah. The last two are elizabeth with the duf and cornea bludge=60% and 0%. The light for the reflection is a point light.
    Congrats for the last two.
    But the real photo (top) you compare with doesn't have a pointlight. wink
    My guess is a spotlight would probably be closer or possible a emissive surface but I have been evading the later one as from my experience the scene takes often longer to complete with them. What kind of light have you been using in your setup for the image from the fiddeling thread ( here )? Or is it only from the environment map?
    I used two spot lights with some rectangular surface (10cm and 50cm). My hint: you can use simple emissive planes with only 1 division. The simpler the geometry (of the emissive surface) the quicker the render.
    My renders were 15 to 60 minutes (depending on the skin shader) at 2000px with CPU-only.
    Ok tank you. I will have to do some more testing with the emissive planes.
