Transform "set" function?
I don't know what I need to look for or what I need to ask regarding what I want to do. I will try and be clear for you as best I can. There is an attached file for reference.
I had made a creature which I had bent all over the place to create. In doing so, it's posture requires X ROTATE to be 26.56
Is there a way to make this set as a default X ROTATE = 0?
Thanks in advance!
546 x 438 - 17K
  • Richard HaseltineRichard Haseltine Posts: 112,366
    With the Joint Editor tool active there is a Bake Rotations option in the right-click>Edit menu which can be used to do that.
