4.9 is not keeping render settings in a saved scene
Hi,
I'm finding that 4.9 is not keeping render outputs in a saved scene. It seems to keep whatever is used in the last scene.
This becomes a problem because I am using Dimension3D's batch renderer so it is rendering and saving over each new render.
For instance the attached image "Render Target" should have been direct to file. The image name should have been a different name.
Any advice will be greatly appreciated.
Cheerio
lululee
689 x 523 - 73K
    I've noticed this as well. Also when you press the default button in render settings t does not reset dimensions like it did in the previous verisons.
  • Richard HaseltineRichard Haseltine Posts: 111,374
    Which version of 4.9? I recall someone having a similar issue but I can't recall if it was changed in a later version.
  • lululee1lululee1 Posts: 346
    My version is 4.9.4.117
    Cheerio
    lululee
  • TaozTaoz Posts: 10,346
    Not a bad thing IMO if you prefer a certain general setting - default (whatever it is) is not necessarily what everyone wants.
  • TooncesToonces Posts: 919
    I noticed too when upgrading to the latest version. Even after pressing default, the auto headlamp sticks to 'Never'. It always used to jump to 'when no scene lights'. I actually kinda like the change since I prefer Never.
    Has anyone found if there is a fix to not holding the render settings?
    Cheerio
    lululee
    Is it all settings or only some that aren't kept? Those I've checked like Dome Rotation and Dimensions are kept when I reopen the scenes.
    Hi Taoz,
    In The attached image "Render Target" should have been direct to file. The image name should have been a different name.
    So it is losing the Render Target and the image name which means I can't do any batch renders.
    Cheerio
    lululee
    lululee1 said:
    Hi,
    Cheerio
    lululee
    OK, I see what you mean. Could be fixed with a small script that watches the folder and renames the files as soon as DS has saved them. If you're using Windows I can write one.
    Hi Taoz,
      I am using Windows. I would be soooo appreciative for the script.
    Because it won't hold the correct file names and just keeps rendering over the last I can't use Dimension3D's batch renderer for all of the promos..
    The script would be a much valued gift .
    Thank you so much.
    Looking forward to the script.
    Cheerio
    lululee
    edited July 2017
    @lululee1
    OK, here's the first version, try to give it a test run to see if it works on your system. Just put it in a folder (avoid any of the Program Files folders) and run it. You may have to run it as Administrator.
    First select the "watched" folder where the DS renders are saved. Be sure it doesn't contain any other files, or they will be renamed too. If you want to create a backup of the renders on another drive or whatever as soon as they're saved and renamed, then select a backup folder.
    Then check the Test checkbox (before clicking Start) and click Start. Copy some files into the watched folder and check that they're being renamed. If you have selected backup, check that files have been backed up.
    By default it checks every minute, if your renders take a long time you can set it higher so the risk that it tries to rename while DS is saving the file is smaller. It does check if the file is locked or in use before trying to rename it but these checks are not 100% reliable. I've tried to make it not crash if it happens but it's not fully tested yet.
    Let me know how it works (or not).
    http://taosoft.dk/software/freeware/brf-ds/BatchRenderFixDS-0.500.zip
    Virus report:
    https://virustotal.com/en/file/31666d9c346f66f8b58eb9652af701ab1ec434cee663ea57b55b61f727ebed72/analysis/1499821875/
    Post edited by Taoz on
    Hi Taoz,
    Thank you soooo much.
    I'm away from the computer until tomorrow afternoon.
    Will test it tomorrow afternoon.
    Cheerio
    lululee
    Hi Taoz,
       I cannot thank you enough for this life saver that works purrrfectly!
    What a gift. You've made me very happy. I can now use my batch renderer with no problems.
    Have a wonderful evening.
    Cheerio
    lululee
    lululee1 said:
    Hi Taoz,
    Cheerio
    lululee
    You're welcome, glad it works for you! I was just wondering, if there are other render settings that also are not saved, will that not cause problems?
    Taoz said:
    lululee1 said:
    Hi Taoz,
    Cheerio
    lululee
    So far it doesn't seem to.
    It is holding the direct to file, and the image size.
    I did render it in in Dimension3D's batch renderer and so far so good.
    Tonight I will do more higher end renders and will let you know in the morning.
    Again, Thanks so much for your help.
    Cheerio
    lululee
    lululee1 said:
    Taoz said:
    lululee1 said:
    Hi Taoz,
    Cheerio
    lululee
    Cheerio
    lululee
    OK. I've made an update though, I'll suggest using that instead. In the first version a messagebox may pop if something goes wrong, this will stop the program until you close it. I've replaced it with a log file that will log the errors instead, so the program will keep running.
    Also note that if you use the backup option files that are backed up will be overwritten if you start a new batch which generates the same file names.
    http://taosoft.dk/software/freeware/brf-ds/BatchRenderFixDS-0.501.zip
    Hi Taoz,
    Thanks so much for the update. I really appreciate it.
    I woke up this morning to find 9 beautiful promo images rendered with you first build.
    Stunning.
    What a great gift.
    Will use the new build next.
    Cheerio
    lululee
    lululee1 said:
    Hi Taoz,
    You're welcome! Glad to hear everything went fine. Let me know if you should run into any problems...
  • Causam3DCausam3D Posts: 217
    This is handy as hell Taoz, thanks so much for writing it.
    However, the original question about not saving settings is what landed me here from Google.  I'm creating a product and one of the features is that it needs a render filename to be saved as the EXACT same thing every time.  So I created a render settings preset and made sure that when I saved it I had the Image Path and Image Name boxes checked.  However, it is not loading this Image Name or Image Path when I load the preset.
    I hope that all makes sense.
    Anyone have any ideas?
