Real Basic Shaders Question.
Blackbirdx61
I notice applying a shader tends to grey out a toon.
Is there a way to apply the base shader without disturbing the top level Texture Jpg? And would reapplying that Jpg conflict with the Shader. Im mostly looking to replace some of the IRAY/3DL underlying shaders with the DAZ default Shader, 1. because some mats wont even show prior to rendering which is all but useless to me. And two because I tend to mostly low light work neither of which seems to work as well as v4 did.
I doubt you can even do the above in the Kodachrome world of IRAY.
Thanks again for your help BB.
756 x 778 - 141K
Post edited by Blackbirdx61 on
Hold Ctrl while double clicking on the shader, a dialogue box will pop up that allows you to Ignore the textures.
Thanks Jess.
