MORPHING PROBLEM
Hello :)
How can I morph between T pose to an idle animation I downloaded ?
Cheers
Ami
  • Richard HaseltineRichard Haseltine Posts: 112,366
    Posing is not handled via morphing, could you give a little more information on what it is you wish to achieve? What format is the downloaded animation in?
  • Posing is not handled via morphing, could you give a little more information on what it is you wish to achieve? What format is the downloaded animation in?
    Hey :)
    I need to make a transition from T pose to the idle animation I downloaded.  the animations are from DAZ website and their name is: Ambeint moves. i used the DAZ installer to install them.
    I can see the animations in the animate lite and not in the library.
    last time i did it, i saw the animations in the pose tab in the library, now i can't see it there.
    is there a way to change avatar ? if i already applied an animation on an avatar?
    cheers
    Ami
